Displays the BFD settings for the specified VLAN.
vlan_name |
Specifies the VLAN name. |
N/A.
Use this command to display the BFD settings on a specified VLAN.
The following command displays the BFD settings for the VLAN vlan10:
# show bfd vlan vlan10
Following is sample output from this command:
VLAN : vlan10 BFD : Enabled Tx Interval : 1000 Rx Interval : 1000 Detection Multiplier : 3 Authentication : None
This command was first available in ExtremeXOS 12.4.
